a simple problem about going next page to do scraping
sonatine
hi, finally i got ZP5 and now i'm creating a template to extract blog addresses,for example this iranian blog provider :
http://www.blogfa.com/Members/UsersList.aspx?dir=05&page=1
now i have a simple problem, as you can see in my template ( i attached that ) it's a simple template, to extract addresses from all pages but i can't go to next page, before this, to extract google indexes or specific urls for certain keywords on google i was using that next button in search engines and they worked perfectly but here this dumb-ass blogfa doesn't have something similar and that --> icon doesn't work ( it just goes to page number 2 again and again) how can i add a function to go to next page ? please someone edit my template or explain simply.
Tobbe
No need to click the next button. The url is very structured and you'd be fine working with just an increaser.
/UsersList.aspx?dir=15&page=2
/UsersList.aspx?dir=15&page=3
/UsersList.aspx?dir=15&page=4
See the pattern? Set a variable to 1 and increase it by one after each page load and go to /UsersList.aspx?dir=15&page={-variable.counter-}.
Also make sure you define when it hits the last page, so it doesn't go on forever.
I uploaded a similar template a while back, a bit more advanced as it also goes from a-z, 1-9. May be a bit overkill for this tho.
sonatine
mmmm i saw that template of yours but u know i'm kinda confused because i never used an increaser before, is it too time consuming for u to edit my own template ? so i can see in action what did u do ?
sonatine
i really appreciate if someone edit my template or say more specific what can i do, of couse Tobia hint was effective but i'm in hurry and it's for the first time i'm using variables in ZP5 and don't know what to do, i made a variable name count but i still don't know how to increase page numbers :(
i'm not dumb it's just in iran a few people know ZP and i always must have self study
Tobbe
@sonatine
First time using variables? You should read some guides then, or buy me a beer :D
sonatine
if u were here i surely made u rich :D and buy u a drink, thanks for your help here is 10 pm and my wife is waiting for me to watch TV, i will report tomorrow and can't show my gratitude enough.
Реакции: Tobbe
