Ability to copy whole blocks of actions including true/false paths between templates.
muchink
Is it possible to add in future versions the ability to copy blocks of actions from template to template, like this one:
Instead of having to copy each one and then to re order them..
It would really help and ease the process of adjusting many templates at once.
priestxandar
This was suggested long ago, and would be HUGE help, but i guess only few people need this feature and it's not getting right attention. Come on guys vote for this feature to be implemented asap.
irmscher
Yes, was promised to get implemented long ago, I thought it's going to be in v5...
There is such a task and there is work in this direction, but this is not simple/easy to implement. Looking forward for this as well.
Реакции: bigcajones и Mankush
muchink
Thanks for the update!
