Canvas Very Small in Project Maker
steven_ucf
I started a new template and the new canvas size is very small compared to what I had in the past. I didn't knowingly change any settings.
Does anyone know why this would be or how to fix it. As it is I will run out of space on this canvas.
I am running v.4.5.0.1
Thanks,
Steven
I'm not sure what you mean. Can you provide screenshot?
steven_ucf
RE:
Here is a screen shot, the white space is very small - i can not make a very large template the way it is.
FYI, the white space that you can see on the print screen is all that there is. If i scroll up or down anymore it goes to the light (blue/greyish) background.
EDIT: I Can go 5 more Blocks Down (from the lowest block on the screen), then I reach the end of the canvas.
Just move your actions out of visible white space and you will get additional white space in your project.
steven_ucf
thank, thats crazy I never noticed that:-)
Thanks for the help.
