I wanna check text presence of two text that have the same value.
The form is like this:
Form Details: Every time i put a value and press the verify button it will show OK text under the form, if its not suitable then it will display a random error text.
I make two check text presence for the 1st and the 2nd OK.
So the problem here, if the 2nd text don't display OK it will only show check for the 1st one and not the second ones.
Check Text Presence Setting Tested:
*FIRST (it only check for first OK and doesn't check for the 2nd OK)
*LAST (it only check for first OK and doesn't check for the 2nd OK)
I can check it with ALL but it will require me to check the 2nd line of the list in a text file.
Are there any better way to check not using list?
