Error launching Threads? Need help!
So I got up this morning ready to test out some tweaks I had made to a template before going to bed last night. But when I loaded up ZennoPoster and added a thread it gives an error with the thread launcher. It gives this error even if I add threads without a template loaded so it's not a problem with my template. But I've got no idea what could be causing it. Here is the error log:
2012-05-12 7:52:41::358 Error Setting search:CacheCookiePath Setting not found
2012-05-12 7:52:41::686 Message Log initialization Log is saving to the file: C:\Program Files (x86)\ZennoLab\ZennoPoster Standard\Progs\logs\2012-05-12 7-52-41--686.txt
2012-05-12 7:53:17::186 Error Setting search:instance_filename Setting not found
2012-05-12 7:53:17::186 Error Setting search:ShowInstanceWindow Setting not found
2012-05-12 7:53:17::186 Error Thread launch error Object reference not set to an instance of an object.
2012-05-12 7:53:17::702 Message ZennoPoster Number of threads is increased by 1
I need help because right now I can't do ANYTHING with ZP!
