[SOLVED] Found problem with yahoo
warrior
I found problem while forwaring yahoo.co.uk accounts
when you loggin to yahoo.co.uk account and you need to click on options the mouse busy sign come there and it comes continuously i tried to click using regex but it open a popup i tried disabling popup also but it doesnt helps i dont know if this is some bug or not but i want to tackle this problem :huh:
so i want to forward yahoo emails and cant do with zenno looking for a possible solution
Thanks a lot for informing. It happens with Yahoo.com as well. We made some tests and reproduced this issue. Will be fixed.
asteria
I was hoping this gets fixed in 4.1, but it didn't. For the meantime, disable scripts when logging into the Ymail and you should get an option to revert back to their classic mail. Hope this helps.
Should work in future build.
