hectic problem - help needed
  • Автор темы Автор темы webmuthu
webmuthu
And, will you clarify me please!
i'm making a common bot for multiple sites. sites contains login page and with posting that's all.
just like CMS sites.
when i record some pages which is not suitable to all pages.
simply i faced a problem in login page. some are with captcha and some were no captcha and search field too.
i did something and i logged into content page. content page have topics. topics may vary in links. some pages were 1, some were 2 and even some were 5 in random order with various languages.
but i have too many sites.
how can i select a particular link like "forum" if available on the page? - this is the major doubt.
can i use javascript?- if so how can I? – any samples
and another is select field. some postings have single select field and some were with sub type selection field.
i want to select a random value in select field if available on the page? - another major doubt
how can i find a textbox if available on the page?
and if available some work and if not some work how to achieve this.
how can i find a captcha available on the page?
important thing is - i not record a particular page and do those things.
you really understand my problem?. sorry for ambiguity.
i can't able to chat with u. our working times may vary.
i'm extremely thanking you for your valuable guidance.
Okay, first the captcha problem. Record a page that does have a captcha. Then when the template gets to that point on a site that doesn't have captcha just go off of the unsuccessful exit (red dot) to bypass the captcha or you can set the captcha as optional by right clicking on the action and setting it as optional and zenno won't fail to follow through. The same goes for most of your problems here. Record every possible scenario on different sites like if there is forum link or not and either use red dot to go do something else if it doesn't exist or set this action as optional and if not found zenno will skip it and move on.
Links on html usually looks like/within "&" -------"http://...../forum/....."
So find them is easy:
"http[^"]*?forum[^"]*?"
OR:
"http[^"\r\n]*?forum[^"\r\n]*?"
(?<=")http[^"\r\n]*?forum[^"\r\n]*?(?=")
If forum,phorum, bbs.....etc, then:
(?<=")http[^"]*?(forum|phorum|bbs)[^"]*?(?=")
it should work.
