Help, click into element inside a specific div
EtaLasquera
I must click into a element inside a div, sometimes the page have "1~10 links" with the same name but I need to rise click inside a specific div:
<div class="ng-isolate-scope" vr-pagination="" page="transacoesPage" page-quantity="transacoesPageQuantity" page-limit="pageLimit" page-change-request="changeTransacoesPage">
 <a class="ng-binding" href="javascript:void(0)" ng-click="changePage(item.page)" ng-class="{'active':item.page === page}">2</a></div>
<div class="ng-isolate-scope" vr-pagination="" page="listaPage" page-quantity="transacoesPageQuantity" page-limit="pageLimit" page-change-request="changeTransacoesPage">
</div>
<div class="ng-isolate-scope" vr-pagination="" page="nfPage" page-quantity="transacoesPageQuantity" page-limit="pageLimit" page-change-request="changeTransacoesPage">
</div>
<div class="ng-isolate-scope" vr-pagination="" page="relatorioPage" page-quantity="transacoesPageQuantity" page-limit="pageLimit" page-change-request="changeTransacoesPage">
</div>
</div>
I must rise click in tag <a> of "page="nfpage"... allright I can use by "match" but the order of these elements are random and "nfpage"
Hi. It's not very clear what You ask.
Seeing URL and exact element You want to click, there would be much easier to answer :-)
EtaLasquera
Argh... it's hard to explain :S
I have too many...
"<a class="ng-binding" href="javascript:void(0)" ng-click="changePage(item.page)" ng-class="{'active':item.page === page}">2</a>"
I must click in that link inside the...
<div....page="transacoesPage"...>
The problem is the page order,sometimes the link is match 2, 3, 4, 5, etc...
There is a way to make a click into element inside a specific div?
For now I'm counting the element "page" and check the match to rise a click but I think a easy way exists....
EtaLasquera
Up! As attached example....
There is a easy way to rise click in...
tag: div
Element page: transactionPage
sub tag: a
Element innertext: 2
The attachment example is mine current action to find match....
EtaLasquera
LightWood
This task have some solutions. U can't solve it via a "standard" action.
Of course I can translate u for example, but it is a lot of mine time.
1. U can to try translate this article - http://zennolab.com/discussion/threads/xpath-universalnyj-c-shag-raboty-s-ehlementami.20830/
2. Also u can use part of my explanation in my article - http://zennolab.com/discussion/threads/pravilnyj-poisk-ehlementov-na-stranice-i-rabota-s-nimi-osnovy-i-xitrosti-dolzhen-znat-kazhdyj.23622/
Part start from this part of text "Теперь попробуем разобраться с присваиванием значений несуществующим атрибутам"
If u won't can to translate, I will help u solve ur task.
EtaLasquera
Work like a charm!
Thank you! You don't save my life but turn it more happyness :-)
