How can I post text into a iframe body?
zennoabc
on ohlog.com, I can When I type text into the blog body window(it is a iframe element), it does not record to the project. What should do?:confused:
Try this action
zennoabc
Thank you rostonix!:az: Thank you for the help!
but: What is the difference between 'innertext' and 'innerhtml'?:confused:
Test via action designer:
Try to GET innertext and innerhtml for any div. You will see :-)
