How to pass all variable(not only the same name variable) in "project in project"?
hunthunt
I know "project in project" can pass the same name varible.
How ever this is not enough for me.
I need to pass any new varialbe, and dont need to add this variable in another project.
My project is look like a articleposter template.
Atemplate=get link,get article(one template)
Btemplate=login website,post(many sites, each site has one template)
Ctemplate=save url to excel(one template)
it is working good.
Example:Then I add a variable in Atemplate, such as "uploadpicurl", it can not pass the "uploadpicurl" variable to all Btemplates, I need to add a blank variable "uploadpicurl" to each Btemplate.
For less Btemaplte, I can do it manual. But for large number of Btemplate, such 100,1000, it is so hard to do it.
nicanil
You cannot do this. As you've already mentioned you can pass same name variables or by specifying variables one by one in action settings.
But... I would recommend you to use config files (simple txt List or Table). Create this file in main template, save it somewhere and then pass path to this file to the inner templates.
hunthunt
Ok, I may try some other ways such as the zp3rd global variable.
