Hi people!
I have some questions about Zenno Poster.
Is there any way to start the program and tell ZP how many instances it needs to open? For example I know others programs can do that. Ex. a program can be started via a bat file and adding some data as "parameter" it can open X amount of instances.
I want to know that, to avoid me to restart the server and start Zenno again by hand.
I want that every 4 hours my server reboots and with a single line I could re-start Zenno, but I need to set up by hand the amount of instances I want to be opened.
Its just because I saw some weird problems with my ZP. I detected that sometimes instances "crash" or just stoppped to work.
For example I have a template running 1 time every 4 hours. It has 100 threads so I opened all instances and they wait for a task. As soon as schedule loads a new tasks all them start to work. But when all 4 hours have passed, and a new task is loaded, some instances are not counted on the new task. They simply stop to work.
My last night test gave me the following results:
1st Task: Completed with 100 threads.
2nd Task: Not Completed, it only took 62 threads.
3rd Task: Not Completed, it only took 32 threads.
4th Task: Running with only 24 threads.
I really dont know why Zenno doesnt take ALL threads again. It stop and lock instances to a previous task and dont use them on the new task.
So I decided a good way to avoid this kind of crash is reboot the pc/server or interrupt threads and start them again, but I prefer to reboot the pc cause it can be made using bats.
But to get the above process 100% automatic I need to know if there is any way to start Zenno and tell it that I want X amount of instances started waiting for a task.
Hope someone can help me, I searched all the forum and ALL questions about this kind of problems were not replied.
Damian
Damian
