Implementing CodeCreator project in VS Solution?
  • Автор темы Автор темы Ambassy
Ambassy
Basically I've written a CodeCreator project which I want to use as a class library in my Visual Studio solution.
I've imported the project and added the .dll files.
However I see that the 2 arguments:
Instance instance, IZennoPosterProjectModel project
are being added to the main method somehow.
How would I go about this is my solution where the ZP project isn't the startup project (but merely a class library project)?
You have to include these arguments if you wanna operate with instance or project objects.
Thanks for replying.
I know I have to include them but how would I create them?
IZennoPosterProjectModel is an interface so I need to know the concrete class in order to instantiate it.
Instance takes 3 arguments in its constructor (string url, int port, string address) - what do I input here?
I mean right now my class is implementing the ExecuteCode function in the following way:
public class McManager : IZennoCustomCode
  Instance instance;
  IZennoPosterProjectModel project;
  public int ExecuteCode(Instance instance, IZennoPosterProjectModel project)
  this.instance = instance;
  this.project = project;
  return 0;
But how do I call ExecuteCode? I don't know how to instantiate neither of the arguments and it doesn't get called when I instantiate the class itself.
I cannot create project or instance objects within a code.
But you can develop your own dll in Visual Studio and use it in your projects with GAC + using.
Alright I'm not familiar with GAC so I guess I will just setup a task in ZennoPoster which starts when a textfile is created (containing my arguments). Seems like the simplest solution to communicate between my custom program and my CodeCreator program.
