"Input string was not in a correct format." when increase counter?
joe009
as the title says really
i get
when i try to increase a counter, what am i doing wrong?
We are aware of some bugs in Input Settings module in current version.
Please wait for fix in next build.
zeus
i get
what value did you give in counter?
it should be numeric,and not the variable.
you select the variable in the variable name.
@rostonix: He is asking about the counter,not the input settings.
Yep. It was night.
OP, please provide a screenshot of action's settings that cause error
joe009
Noticed the problem myself just when I was taking the screenshot. In the module i was setting the counter to its initial value i had changed the variable from the counter one so when it was tring to increase the counter it must be an undefined variable or something. spent an hour looking at that yesterday cant believe i didnt see it. Anyway solved now i think :-)
Good to hear :az:
Реакции: joe009
