Is there still some problems with connection to zenno servers ?
  • Автор темы Автор темы lokiys
Another problem in email bulk action:
System.Net.WebException: The remote server returned an error: (404) Not Found.
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at ZennoLab.MailHandler.Helpers.MailSettingsLoader.WZ2Oho5AB4qyFvdi7RhR(Object , Object )
at ZennoLab.MailHandler.Helpers.MailSettingsLoader.GetServerSets(String server)
at ZennoLab.ZennoPoster.Modules.Email.MailDownloader.JVRAM8tMSvPrMEfOc15n(Object , Object )
at ZennoLab.ZennoPoster.Modules.Email.MailDownloader.wUrfEP9NivC(MailTask& )
Probably Indy because the authorization server was down again today. I had the same problem in a template I was debugging. Shut down PM and then when I tried to restart got the message. You know the message. The message that for some strange reason has popped up in the last 2 days.
Any news when this connection problem will be solved ?
Now i'm getting this error in bulk email action.
Object '/477f81fa_35f6_469e_808c_b057df0045d7/swrjdj_ywoqdz3rkahhwagsh_7.rem' has been disconnected or does not exist at the server.
Replied it skype group. Copy it here:
1. About bulk mail loading: mozill server for mail auto-config has been changed. So you have to specify all parameters in ZennoPoster MP now. In ZP 5 it is fine with auto-config
2. about Object '/477f81fa_35f6_469e_808c_b057df0045d7/swrjdj_ywoqdz3rkahhwagsh_7.rem' it seems pipe was closed by timeout, task gonna be set for future analysis
Any news about this ? Or i need to remove bulk email action ?
Also i have got some weird error in bulk email action before when it was worked.
When you have like 2000 emails in box then you got error that said - Emails is more than some MB and can not be downloaded. I checked http://help.zennolab.com/en/v4/zennoposter/macros/4.3.5/ZennoLab.CommandCenter~ZennoLab.CommandCenter.ZennoPoster~BulkMailDownload.html
But did not find how to specify size of all emails.
and what about this ?
What build do you use right now?
This is not build problems, but your server problems...
Выполнение действия OwnCode Object '/59ba4912_7af7_4533_9e89_8dad79a7fc1a/pgyi9dnuuibbdcuqevikzhsl_22.rem' has been disconnected or does not exist at the server.
No difference what build... - - - tested with v4 and v5
Take 1000 lines with removing a few times as current work around
I have to ask why there is no immediately input to resolve this problem ? Or at least give clear answer that problem is there and any estimate to resolve that. This is major problem.
For checking that this problem exists need 3 min, but now i'm not getting clear answer from 06-06-13 17:54 12 day - wow...
It is never confirmed by anybody else and never happened to me, but I used to handle big amount of mails via gmail though. Will check it with hotmail
Well looks like there is no users who using bulk email action i guess because i talked with DD today and he confirmed that there is bug.
There is message from him just to let everybody know what is workaround for this...
if you first call of ZennoPoster.BulkMailDownload is after 20 minutes after ZennoPoster starts this could happen.I will try to fix this bug to the next release, right now you can use such work around
Make a template with C# macro with one line return ZennoPoster.HttpGet("http://chek.zennolab.com/proxy.php");
Schedule it to run every minute 1 time. This should not allow ZennoPoster to close pipe.
Реакции: Hungry Bulldozer
