logical if does not work with variable default value
yann06
I noticed that the logical if does not work with a variable that does not have a value but has a default value.
That forces me to set all my variables at the beginning of the script even though they all have a default value...
Not sure if this is a bug or a choice of design.
Default value will be set as value in project restart and all will be fine. Otherwise please post project where it is not working for you.
yann06
I see what happened. I am working on a big project and I was debugging a section so I did not restart the whole project and the variable did not get instantiated.
Thanks for your help
Then just when you add default value, just copy same in value and you will be fine to test. :-)
