Multi Threading AND emulation cause problems?
mark leenheer
Is there some sort of rule on using keyboard emulation and multithreading?
I thought I read somewhere using KB emulation while mutithreading can cause problems.
Is this true, are there any issues/guidelines with using emulation while multithreading?
No issues.
But when you use keyboard emulation, it will work only in 1 instance per base.exe. Other instances will be waiting while this task will be finished.
mark leenheer
No issues.
AH ok thank you.
So if I want to multi thread while using emulation and execute as fast as possible I would want to reduce count of threads in one process to 1 or is this not advised/needed?
Yes I set 1 instance per base when I run 1 of my projects that requires a lot of emulation.
