Poster does not do the job problem
Hi guys, I just started using Zenno MP and have probably very basic question.
Project works just fine in Project Maker, does everything as neened and saves output files with new passwords (project does password change), BUT
when I start it in Zenno Poster, nothing seems to be happening and no files created.
In ZP I
1. add project,
2. set max threads to -1, medium priority, no labels, use proxy with deletion, and use set of rules for proxy
3. type 1 for how many times to perform project, ZP starts to show progress in %, goes to 100%, but does not save files (again, in PM it worked!)
I guess I am missing something very basic, couldn't even find anybody having same problem in the forum here=)
Question is:
Are there any other settings I need to do in ZP to get my project to work in ZP?
Thanks so much
Stroks
What version of ZP do you run?
4th version, MP v4.0.7.0
Maria add threads 1 or 2 and success more than one. And press show. And check what happening.
Реакции: Maria Arbuzova
Update to last build :-)
Jor1s
Which kind of proxys do you use ?
Maybe you have bad poublic proxy source (all dead or bad country)*
Actually i didnt found any good public source, i bought my own private proxys and it works well.
yeap, Jor1s, looks like it boils down to problem with proxy. I did have a few (about 30) that pass the rule yesterday. But today, after an update to v4.0.8.2, the field "server" in the ProxyChecker is not active and I can't even type anything there. Does anyone can help with setting up the server in ProxyChecker? Any ideas greatly appreciated.
hit me on skype
Jor1s
Please after rostonix helped you, tell me what he says, would like to know how to use public proxy :D
Problem wasn't solved.
Checker is not working on that machine.
What problem do you have?)
Jor1s
Well its about source and rules, but i need to REwatch video tutorial about how to use rules.
Actually i must use PRIVATE proxy otherwise all my template got errors :-), but i never used RULES so i have all kind of country, like chinese.
I must learn how to use rules first.
No) user had another problem)
