problem for using modules with extension cm2
sonatine
Hello everyone,
last year i made some modules by CapMonster Pro and their extension is like *.cm2
now this year i'm using CapMonster Standard v6.0 because i can't use the newest version of CP. because my computer is old and i must use older versions.
now how can i use those modules? because it seems the Standard version use files with .cm extension.
anyway to convert cm2 to cm?
what can i do?
sonatine
this picture explains everything
sonatine
thanks! you saved my life, that's why you guys are the best!
Реакции: VladZen
