problem with proxybonanza
octobus
Hi. I have some problem becouse i add a list of proxy's from proxybonanza and it doesn't work ... have list of 60 passworded proxy with is still running on scrapebox but zend poster cant ... i add it to sources on format login::password@ip:port and no proxy is alive ... anyone use proxybonanza in zp ?maybe i do something wrokg ;/ plz help me
When you add a source try to choose this as paid, login:pass@ip:port
octobus
I do that ;/ i have a file with a proxy from proxybonanza (i repeat, it works on scrapebox) on format:
LoGin:passw000rd@XXX.XXX.XXX.XXX:YYYYY
i select a wizard on "sources" ->"one source"->"file on disk"->choose a file->select paid-> and have:
Selected type Paid
Number of resources to add: 1
Resources list:
C:\proxys.txt
number of new sources added: 1
when i start checking proxy have:
sources: total-1, alive-1
proxy: total-0, alive-0
the port is 61336 is that a difference
doest it work fine with other sources of proxy? contact me in skype and we'll resolve your problem
pk69
bumping the thread...
did you guys get it working? I bought today shared proxies from proxybonanza and loaded them in zenno in the format suggestd
user:pass@ip:port
for some reason zenno doesn't show them as live even I can browse web using any of them.
please advice.
thank you
pk
Здраво
Bumping this yet again, I have the same problem.
neomatic
You may try out this format:
IPaddress:login:password
neomatic
mark leenheer
Use them in http mode. You need to change the port.
I forget what the port is, you can ask them.
