Problem
PureMind
Ok, so I am trying to make a bot that add videos to a view system.
The only problem is the add button on the members page. When I click it and project maker records it doesnt record the click. Right clicking and choosing javascript and "clickthis" it works once. But as soon as another video is added it clicks the button beside the newly added video instead of add new video button (the videos are displayed on the members page).
Tried so hard I could to explain. Anyone have a solution?
So you should use the Pro Branch Builder in case if something was not recorded. Then if next button is similar you should make loop clicks, but only in case if buttons are similar and have universal criteria to be found.
PureMind
Well, in the pro branch builder the only difference this button has from the others is the form number. Which is the element that changes after I have added another video.
