Tumblr Posting Problem - Article Being Posted Many Times
velociphiles
SOLVED: Tumblr Posting Problem - Article Being Posted Many Times
My first Zenno MP template is to post to some existing Tumblr accounts.
In debug mode everything works fine up to trying to post.
I am posting a spun article which Zenno has pulled from a file and set to a variable. In the log the variable is shown with the correct text.
When posting to the article body within Tumblr the article is posted OK, but when the end of the article is reached it starts posting the article again and again...
My guess is this is some sort of problem with the Tumblr interface for posting (does it use Ajax?) and Zenno cannot recognise that the article has been posted, so posts it again.
I have not disabled anything in the browser and am using default settings, but with a private proxy.
Any ideas how to get round this issue?
Hello
Set speed of emulation in settings of this action (article typing) to minimal
Anton
velociphiles
Thanks for super quick reply. I tried your suggestion (I think) but it made no difference.
Here is a 60 second video showing the problem:
http://screencast.com/t/28ZiMoitfwj
drvosjeca
I would first ask you if you have upgraded to latest version... .8.2??? ...because that is something it was happening on a lot of sites before.
I dont see that issue here now.
And one more thing, always try adding few seconds after you click button for adding article/before inputting article in field.
velociphiles
Version is 4.0.8.2
Interesting point about adding a delay. Doesn't matter in this debug case as I have a breakpoint in there before posting.
I had wondered about adding delays but Zenno seems to be good at waiting for everything to load before going to the next step (at least in debug). But it is probably good practice to add some delays - it would seem more human anyway.
I meant to set this setting to speed (not quality)
It should just paste it then.
Did you try this?
Anton
Реакции: velociphiles
velociphiles
Perfect - works fine now!
Thanks for your prompt responses.
