I use some projects to generate and warm-up profiles, e.g. https://zennolab.com/discussion/threads/sozdanie-i-nagulivanie-profilej-dlja-posledujuschego-ispolzovanija.65016/.
My question is now, if there are any negative side-effects if I create the profile with the Chrome Engine and use it later in a project that uses the Firefox (52x64) engine and vice versa?
Are there any points to consider in this context or makes it no difference? Thx.
