Why not work, Regex with variable in a value field ?
eric
hi,
no element to find.
And you are sure that the User Name is on the source of the page? Have you tried the Dom text instead?
Sould work this way. Check source code as Clint said .
eric
Okay, strange coincidence but it happened to me also on a site that I was working on. Okay Anton, can you check into this. If needed I will send you or HB the template.
eric
