anti captcha post error please help
papa-rico
привет еще раз всем
anti captcha документция
есть докуметация вроде сделал как надо все равно показываеь "{"errorId":22,"errorCode":"ERROR_TASK_ABSENT","errorDescription":"Task property is empty or not set. Please refer to API v2 documentation."}"
78505
HTTP:
curl -i -H "Accept: application/json" \
     -H "Content-Type: application/json" \
     -X POST -d '{
    "clientKey":"b5a314803e28a1cab7dd4b63143b786e",
    "task":
            "type":"FuncaptchaTaskProxyless",
            "websiteURL":"https://www.amazon.com/ap/cvf/request?arb=995091fd-4af9-411c-9f5c-9b846c524755",
            "websitePublicKey":"2F1CD804-FE45-F12B-9723-240962EBA6F8"
}' https://api.anti-captcha.com/createTask
что тут может быть не так ?
встроен плгин тоже что то не могу настроит
78504
1) Did you check API documentation? - "Task property is empty or not set. Please refer to API v2 documentation"
2) Funcaptcha can't be solved with standard action for recognizing captchas.
Реакции: papa-rico
hi yes yes checked all works well found a solution for it thanks
