Audio solvemedia How is work.
  • Автор темы Автор темы pita
pita
Hi, i'm a newbie. I need some help. I don't now where to put the snippet for audio solvemedia or recaptcha2.
Does every one had a template for free or for buy with an audio solvemedia captcha solved and recaptcha 2. with capmonster 2. I have the two licences but it's doesn't work. Thank's
Do you plan to send audio captcha from ZennoPoster?
Is that i tried but i don't how to do. Thank's for reply
Thank's i already read that but it's my problem i don't know how to put their code in my template. Can i buy or for free view a template or some picture to help me.
thank's
You just copy paste it to action C#
i do that already... I'm blocked. can i buy or do you have a template with audio solvemedia?
What do you mean that you're blocked?
I do this template with the long code in the first c# and the code to send to captcha service. But is not work their are some mistakes. Thank's you
    102,1 KB · Просмотры: 519
And you dont need to manually click anywhere within captcha with other actions if you use snippet
thank's for the response. but it still not working is better but too much !:) thank's you
    260,8 KB · Просмотры: 726
if i click again on download mp3 their is a page with media error written
what's in logs? i dont see logs on your screenshot
thank's
    170,4 KB · Просмотры: 474
i think you modified code in snippet. it cannot compile
I copy and paste the snippet from the source page. i don't understand where is the problem. I have capmonster open but nothing appends too.:s
    186,4 KB · Просмотры: 497
what's in CapMonster? Do you see audio captchas coming there?
no nothing coming. Maybe is in the parameters of the host file. no?
sorry yes now ther com on but write aaaaaaa for recognition
this is a screenshot
    189,4 KB · Просмотры: 738
Try to change IP / set proxy
thank's i change my ip, it's write always aaaa i use a proxy and it's the same things
i restart and it's work thank's you a lot. Have a good day
Hi rostonix. I need your help again ! ;) now i have a error message with recaptcha 2 and solvemedia like this. Exit code variable is not specified. I understand the sentences but how to set up an exit code variable. Thank's you
Here)
Thank's you it's work very well
