I've got the demo version at the moment and I have 2 problems. I'm not sure if these are limitations of the demo version or maybe I'm just missing something!
First problem: In the template editor I can't draw a branch from one web action to another. Whatever I try, it just wont make the branch appear (the red line that links between web actions).
Second Problem: When recording a web page there there is a green + button and a red - button in the instance tab of the menu. When I try to click the Green + to "open tab" nothing happens. It doesn't open a new tab.
Is this a limitation of the demo version or is something wrong?
I installed it on my Mac using Parallels running XP. I thought that may be the problem so I installed it on my VPS running windows server 2008 and it's exactly the same!!
Please help someone!!
I'm really liking this software but my learning progress is stuck at the moment
TK421
TK421
