Big project need to split and export data?
PAtrykkp
Hello, i have write really big project in ZP.
When i run it, ZP complete only 35 - 50% of my project and going to stop work.
I think i dont have enought RAM and process are frezzy
I need to split it to 4 pieces:
- registration
- verification
- configuroation
- posting
I can split it to seperated projects fastly but how to export VARIABLE names project to next project??
Example:
Registration output X variables now need to get all created data and when i run verification project, i need to import data from Registration project.
Also included lists etc.
Next step: Get data from verification all variables values and export, then import to configuration.
etc...
Any solution?
copper12
EtaLasquera
You can send and receive variables between projects, variables can use the same name or different names.
By default I use the same names but that is not a rule.
To use tables or lists between projects you must assign the table/list to a file.
