Cap monster Http requests error fix and update error fix / someone help me
meskai
So recently my cap monster stopped pretty much working, when i press update button it just throws error ( Error | Update failed with error:System.InvalidOperationException: There is an error in XML document (1, 1). ---> System.Xml.XmlException: Data at the root level is invalid. Line 1, position 1.)
Anyone knows fix for it? Another problem i started getting is when i use http requests solving methot for recapctha v2 i get only ip bans and bad ips.
If you have problems with httprequest method, then install the latest version.
Update error is some internal thing, which should not affect program work.
oxsl
