Code Creator add reference issue
  • Автор темы Автор темы unkn0wn
unkn0wn
Hi all,
I just installed demo version of ZennoPoster and love it will purchase full copy soon.
However before I do I have one big issue.
I run Visual Studio 2010 and compiled Simple Library Class (.NET 3.5) nothing special.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace TestCL
    public class TestBlahTest
        public int TestProp { get; set; }
Then I included compiled version as a reference in zenno poster
and included namespace.
using Zennolab.CommandCenter;
using TestCL;
namespace NewProject
	internal class Step1
		public static int Execute(Instance instance)
			//ZennoMaster.Models.Enums.PublishSourceType a = ZennoMaster.Models.Enums.PublishSourceType.HubPages;
			// Clearing cookies
			TestBlahTest tst = new TestBlahTest();
			tst.TestProp = 10;
Then pressed play and I get this error:
If anyone can assist me with this issue I'll appreciate a lot, this is the only show stopper for me before I buy software.
You can reply in Russian I can understand Russian very well.
Hi all,
using System;
using System.Linq;
using System.Text;
namespace TestCL
using TestCL;
            // Clearing cookies
            tst.TestProp = 10;
You should try to copy your dll to ZP folder. And also you should check that your dll for .Net 3.5 and not .Net 3.5 Client Profile
Реакции: unkn0wn
Awesome that worked like a charm, so I have to do that with every assembly, right? zenno won't do that automatically?
