Count how long project ran for + shutdown project if runs longer than 4min
aidenhera
Hello
I have many projects and some Id rather exclude from running these that are too long. for example if you can get good backlink within minute and then other website takes you 5min when scalling its not worth it to keep 5min projects.
1. Is there a way to see how long project ran for last time? I have no idea how to implement this.
2. Other thing I was wondering about was if theres a way to shutdown a project if it rans over 5minutes (cause sometimes they might fall in never-ending loop).
I tried looking for such features in ZennoPoster but there are none so I guess it has to be added to each project in some hacky way.
Thanks for help in advance!
That's logic task... For example, you may get current time and compare it with start project time. If the difference iis too large - then stop the project.
Реакции: aidenhera
aidenhera
Реакции: aidenhera
