{Enter} inside a variable does not work in Keyboard emulation
Robejon
I have a whole paragraph that is inside a variable. However when I try to enter this text with keyboard emulation, all text formatting is lost. Hence I tried to insert {Enter} , as well as {-String.Enter-} in between the text , inside the variable itself.
However it simple inserts as Enter instead of a new line.
What is the solution?
How do you expect macros will work inside macro?)
You can enter text with Action Designer>Set>value action into innertext or innerhtml attribute.
I think it's better for formating..
