Excel - if load from input settings/variable
aleksa77
When i put option in input settings "file name" and when load excel table it give me this :
And this is settings:
When i load excel directly in table all is fine:
Obviously, there is something with encoding... InputSettings have not being updated for a long time.
You should set proper encoding in your Exel file.
Реакции: aleksa77
I'm wondering how You still use file paths as variables in List and Table settings.
If You use variables You have to BIND files to lists or tables.
Реакции: aleksa77
aleksa77
yes, I was bind, tested 100 times with diferent variants, then i make new project with only this test, and then works...thanks, but Zenno is so buggy , problem is because i found bugs usually in middle of projects with tight dead line, and always is panic, i will need works with zenno in free time to collect all problems
