[SOLVED] Exit Code issues when using a .bat file to add attempts to another project
BFlame6
I have a project that uses a Zennoposter created .bat file to add one attempt to a project.
When running the original project, it does run the project that the .bat file calls successfully.
However, the problem is that it returns an exit code of "1" instead of "0" so it goes to my "Bad End" set of actions instead of through the "Good End" actions.
I have tested my own, third-party, .exe files and all successful exits have been returned as "0", but Zenno's .bat returns "1" and then goes to "Bad End."
Is there something that I am doing wrong?
thank you
Will be checked.
Fixed . Will work fie in next build.
Реакции: BFlame6
