Help with my Proxy checker problem
prosperer888
ZPMP didn't found any alive proxy with my proxy source, but when i use my ZP3, it will scrape thousand of alive proxy with proxy source that i use with ZPMP...I just install ZPMP and ZP3 on my vps so they still on default setting....anyone had a same problem with mine?
email support and forum support ignore me completely.......this suck mannnnn
Use Zenno 3 as stable release.
ZennoMP is an open beta.
You shouldn't expect too much support for this version. If you decided to test it and use it, you can do it.
If you think that you found a bug, you can post about it here on forum or directly to developers email.
Developers are working on all known bugs to make ZennoMP official release as soon as possible.
Thanks rostonik for the reply and now after teamviewer session with support and it already work :) it only take he few second to fix it :)
