Help with operhands and js Operators
  • Автор темы Автор темы bambinou
bambinou
I am still having a little trouble with all the JS Operators.
Equal (= =): returns true if the operands are equal.
Not equal (!=): returns true if the operands are not equal.
Greater than (>): returns true if left operand is greater than right operand. Example: x > y returns true if x is greater than y.
Greater than or equal to (>=): returns true if left operand is greater than or equal to right operand. Example: x >= y returns true if x is greater than or equal to y.
Less than (<): returns true if left operand is less than right operand. Example: x < y returns true if x is less than y.
Less than or equal to (<=): returns true if left operand is less than or equal to right operand. Example: x <= y returns true if x is less than or equal to y.
Right Now I have a parsed text, it's execution result is:
{-FieldData.FieldData-|-●8●2●3●7●1●1●-|-tp-5427-}
I would like to send the bad urls in a txt file and the good urls in another txt file.
For that I added a Logic "if" step with:
'{-FieldData.FieldData-|-●8●2●3●7●1●1●-|-tp-5427-}'=='Thank you!|Thank|thank you'
Red cercle ---->Go to a txt file
Green cercle ----> Go to another txt file
What I don;t undertand is that the good urls are going to the right txt file but the bad urls are not going anywhere.
Any idea if my operator is correct? Did I write it properly?
I have seen some programmers writing their expression this way:
'{-FieldData.FieldData-|-●8●2●3●7●1●1●-|-≡1≡8≡0≡8≡7≡6≡8≡1≡9≡1≡-}'!=''
Is this valid??? I am so confused .
Thank you,
BamBam
