Help
ricalian
I am trying CapMonster with Faucet Collector. Not having a good time really and I need an step by step support before buying the software.
I have tryied without proxy and it worked fine for an hour then I began receiving ip_banned_error. I downloaded GSA Proxy and searched for proxies. Most of them garbage.
Could someone please help me to 1- configure GSA to search for the correct proxys, 2- configura CapMonster in order to make it work as it should.
Now (after several tries) nothing is working...
kingbin
IP for ReCaptcha need rotate proxy or 4G LTE proxy for the best performance. These proxy have a big big ip pool for rotating and you dont worry about banned by Recaptcha. Free proxy always not good because almost of them have bad ip which was banned by spamming.
Реакции: ricalian
ricalian
How can I do that (use a 4G LTE proxy)?
kingbin
I would recommend you these proxies for solving recaptcha in CapMonster.
