How extract text to a box! really need help!
  • Автор темы Автор темы tuppan
tuppan
:confused: Im creating a template to login then go to wallet page, and transfer money to other user.
but i need to set the amount, how can i extract a text ex: $800,00 then but in form only 800,00.
its a simple text
here is the css code
please really need help!
Реакции: tuppan
thank you!! it work really good!!!! i used string.replace to remove spaces and "$" of the text found by regex then out it in amount box!! man, i love you kkkkk! im joking! :p
:D:beer:
