I have a problem with SOCKS
qioru
I have a problem when using a SOCKS5 list. I tried 2 ways:
1) with a text list containing a list of SOCKS5
2) with zenno posters proxy checker
In both methods even if they use one or more threads is a difference between set and real Socks
Here are photos and project
  • 362,2 КБ Просмотры: 382
If you use this proxies in usual browser is youк real IP hidden?
qioru
In normal browser (firefox Ie) runs these socks. I have an account at anyproxy.net . Normally I want to make a ssh dynamic forward connection and use local socks - but same problem in ZP MP . I mean, I have this problem only when using socks connection. No problem with http proxy
qioru
Yes, in firefox or IE when using these socks my real IP is hidden
Hit me in skype. Will connect via teamviewer and test
qioru
Guys,
any news?
qioru
Can anyone tell me how to fix this? I need to use socks and I can not. I thought that the next release will be solved. But I see no solution. Can someone tell me how to use Zenno Poster socks and avoid problems reported? .
Was reproduced.
Will be checked. Thank you.
Possible solution: use 1 thread per base
It is advised to use http proxies instead of socks cause FireFox has problems with them: it's not possible to limit connections to socks in FF.
Реакции: qioru
qioru
thanks I will try this way
awzse00
I also have socks from anyproxy, and got the same problem. Did you managed to get this fixed?
