Lots of problems with DeathByCaptcha
muchink
Hi!
I'm having lots of problems with deathbycaptcha with many of my templates that used to work perfectly,
many times I receive "The remote server returned an error: (502) Bad Gateway."
is it possible that somehow the problem is connected to ZP or it's only because of DBC?
Thanks!
Module in Zennoposter didn't change. Suggest you to try other anticaptcha services.
muchink
Thanks, Will do!
I have another question,
since I've got over 40 templates, it would be really headace to go over each one of them and change it to other service,
is there a way to change them all at once since they are all at DBC?
riken
I'm having same problem with DBC, they say is Zenno, Zenno says is DBC
But I do think the problem is with DBC
dyscus
idem problem with deathbycaptcha error 502
Thanks, Will do!
You should add variable in all templates and then you can change captchas service at once for all templates...
muchink
Thanks! I didn't know that it's possible to customize the text over there!
mikelac
I was getting a ton of Bad Gateway errors with Deathbycaptcha.
But it seems to be working much better the last 3 days or so.
They must have been getting lots of complaints because it has been a problem for a couple of weeks that I have noticed. Seems like they must have "fixed" something on their end. But I'll probably go back to Decaptcher when my balance runs out.
Anybody else notice an improvement with DBC over the past few days?
Mankush
nope. I went to anti-gate.
