module problem
bill
So I was training module and getting 0% recognition rate when the symbol recognition rate was high. I tested the module and I saw that the correct results were incorrect. You can see in the picture below, I am confused because I assumed correct result would be the completed captcha. I used decaptcher to decode the captchas so I don't understand why the correct result is not the the captcha... Please have a look
You sure that decaptcha results are correct? Were CapMonster 2 main application running, when you recognized captchas via decaptcha?
bill
No only capmonster mcs was running
