Multithread problems
  • Автор темы Автор темы lokiys
I have talked about this before and i saw some improvements in this, but anyway this is not acceptable to get results like this...
First pic is my media wiki template with one thread and second pic is that same template but with 15 threads....
15 threads:
Using 5 threads per base...
Where i should add pauses ? Why pauses can make different success rate for one thread and multithreads ?
Before not found elements. Isn't that evident that 1 thread load network much less than 10? Any site loads much faster in 1 thread and longer in 10 threads. So some elements could be still not loaded while loading status is green (AJAX or loading longer then timeout).
Ok will try but as you know this problem is there long time, as i remember i started thread where i showed that same with hotmail all to inbox template...
Also i have no any problem with connection i have optical cable in my home with 100+ Mbps direct connection and not any shared. ;)
Anyway will try...
Why do we have to find a way around all those bugs when you just don't care to fix them?
