C chan Client Регистрация 11.03.2011 Сообщения 17 Благодарностей 0 Баллы 0 15.03.2011 #1 I don't know what's the problem with it. can some one give me some advises. Вложения dlvr.it.xml 14,6 КБ Просмотры: 530
joma Client Регистрация 06.03.2011 Сообщения 107 Благодарностей 13 Баллы 0 16.03.2011 #2 I had the same trouble before. If you working with ajax forms, put some pauses between the branches. hope that helps joma
C chan Client Регистрация 11.03.2011 Сообщения 17 Благодарностей 0 Баллы 0 16.03.2011 #3 thank you . can you give me an example.
Hungry Bulldozer Moderator Регистрация 12.01.2011 Сообщения 3 441 Благодарностей 837 Баллы 113 16.03.2011 #4 I've not seen your template, but if issue is really with ajax put in the new branch before(may be also after) the ajax actions are happened drag "Get" - "Macros", in macros builder "Work with template" - "Pause"
C chan Client Регистрация 11.03.2011 Сообщения 17 Благодарностей 0 Баллы 0 17.03.2011 #5 i have try to add a "pause",but it didn't work too.
C chan Client Регистрация 11.03.2011 Сообщения 17 Благодарностей 0 Баллы 0 18.03.2011 #6 I set the pause after the branch,it work now. thank you
