need a little help
prosperer888
i create an email account and safe it like this "username@yahoo.com|pass1234"....then i create forum register templates. i try to use the email that i create to fill in the register email column but it fill the email column with "username@yahoo.com|pass1234" that it take from the file...How i can take email and put it on email column and passwords on passwords column with the email format like i safe it.
After you get the login data from file you have to run split string macros. This splits the email & pass into separate executions results that can post to the sites forms.
{-String.Split-|-{-FieldData.FieldData-|-EXECUTION RESULT OF ABOVE STRING-}-|-|-|-0-}
{-String.Split-|-{-FieldData.FieldData-|-EXECUTION RESULT OF ABOVE STRING-}-|-|-|-1-}
| = divider in between data to split
0 = email
1 = pass
The execution results from each split are then pasted into the set value for the email & then the pass.
Реакции: prosperer888
Lol...can you explain more how to do that, because i try to do it and it email from line 1 and passwords from line 2...if can please start the begining..^_^
