Newbie needs help with first bot
  • Автор темы Автор темы phil1966
phil1966
Hi .
Im trying to create a bot that will autopost a random message to my wordpress site as a random user but im totally confused.
when i run the intelli search , it fills the Name with a random name , It adds example@example.com in the email field .
But i cannot work out how to put a random message in the comment box.
Could somebody please advise me
Thanks rostinix, it was the intellisearch that attracted me to the software as im Dyslexic , so programming can be very tough , even more for someone whos new to this .
I will watch the vids again in case i missed something
Intellisearch is handy tool when you have zero knowledge of HTML
If you have basic knowledge, if you know that a tag is a link, that href attribute of it is the link path i bet you will be able to learn how to create bots for websites with action designer http://wiki.zennolab.com/doku.php?id=en:project-creation (tool to record steps based on element's attributes)
If it's hard for you you can go with Intellisearch but i must aware that it's not 100% accurate tool and if you will use only it, maybe you'll have errors in execution of your bots.
Thank you
Im looking for how to create message for insertion to the comments , i have managed to get everything working apart from the control (mmarked with red arrow) that i hope can post a random message to the comments box
    78,3 KB · Просмотры: 433
You should use edit icon instead of green one
http://www.evernote.com/shard/s128/...92ecf84b08d9/96ec21116e0dbb24acddab57702062f4
And when you click edit, you can set your own custom value to be filled.
And if you need to use different emails, lokyis is right, you need to create liste, take line from there with list processing action and put variable that you get in this step into our first action with intellisearch
