Next problem with my template - checking for text presence
player
I'm building a template for registration at pligg sites. For that i need a text presence check so that i can confirm if registration was succesful or not. I use 5 different checks for that. If the 1st text isn't found, the template checks for presence of 2nd text and so on. If all 5 aren't found the site is saved to a txt for unsuccessful sites.
All text presence checks are working good, except the 5th check. I created this check in the action recording mode, so i don't know why it doesn't work.
I want to register on this site: a p p l e n e w s c e n t r a l . c o m
The registration works, but the text presence check not. I'm searching for this text: Safari, Firefox. I can see in the execution result that this text is found, BUT the execution result for the logic operation is "false".
Here are my settings:
1st branch - Checking for text presence
parameters: Safari, \Firefox
execution result:
Safari, Firefox
(And that is the code for the execution result of this branch: {-FieldData.FieldData-|-●8●1●4●9●1●7●-|-tp-5107-})
2nd branch - Logic expression
Expression (js): '{-FieldData.FieldData-|-●9●4●1●1●1●1●-|-tp-5107-}'!=''
execution result:false
Stereomike
try to use the 'prepare for javascript' command for the text. so you'd get something like this (don't know exactly how it will look like, just an example): '{prepareJS-|-{-FieldData.FieldData-|-●9●4●1●1●1●1●-|-tp-5107-}-}'!=''
please post if it worked.
Реакции: player
player
Thx, it seems to work, i used this expression and the result is "true": '{-JS.PrepString-|-{-FieldData.FieldData-|-●3●0●8●1●9●3●-|-≡3≡4≡7≡5≡1≡3≡2≡2≡-}-}'!=''
However, i found an easier to use solution:
"{-JS.PrepString-|-{-FieldData.FieldData-|-●3●0●8●1●9●3●-|-≡3≡4≡7≡5≡1≡3≡2≡2≡-}"=="Safari, Firefox"
But i'm just curious why the expression i created in the action recording mode doesn't work.
