Parsing text problem (and others things)
  • Автор темы Автор темы Stephane
Stephane
Hi all,
This topic because I need help on a template I work on since few days...
I bought some bulk PVA Gmail accounts and I am looking to test them taking in consideration 3 states:
- I can log into this account
- The account is asking for a phone number (which I own)
- The account is dead (I set a new password and I don't remember - I test many other method instead ZP)
Here is a screenshot:
My problem is when I try to parse "COMPOSE" to know if I am able to compose an email so the account is ok, I don't know how to handle with "If" actions. Actually, the "Logical if" contain '{-Variable.Etat-}'='' (Etat = state).
In fact, I'm not sure about my reasoning/way to do what I am looking for.
Any idea?
Regards,
Each action where you make a parsing of DOM or page's source code (marked HTML on your screenshot) as a result have variables with content or empty ones. After each this action you put IF action where you check if something is found or not.
"{-Variable.Variable0-}"!=""
If true - use green exit = something is found
If false - use red exit = variable is empty
