Possible issue with IF?
shabbysquire
Might be me, but in latest build, I can find text ok with Dom action.
But when I perform IF :
'{-Variable.notFound-}'!=''
...it always goes via false, not true. Even when text isn't present, it still goes to false!
Anyway, pic:
shabbysquire
Now you mention trim, I remember doing this before. Just using switch function for now, but will try later on. Thanks!
Use text processing - Prepare Javascript if you have special characters in your text.
shabbysquire
Now there is a major bug with Switch in debug.
When in debug, changing from advanced to normal editor, all my saved text in switch disappears! The first time I put it down to nothing, but now it keeps happening.
Click somewhere within action (to other row after you input your data) and only after this close action or switch to advanced editor.
I think this will help
I have to agree that there is bug in switch - actually it happens not all the time but still happens.
Although I'm not using switch at all can not tell anything about newest versions, but as i see this bug is still there...
shabbysquire
Task was set
Fixed for next build
