problem in macro execution?
  • Автор темы Автор темы purush84
purush84
I registered with a username after submitting my post i need to click the same user name what i have registered to get the output link, But it does not?
1. I used the execution result of username as a parameter value to the rise event
2. i tried to set up a value to the username and the same input as the rise event parameter value, then also i didn't able to click the username.
Kindly guide me as soon as possible.
Thanks!!!
try a event click using innertext or something and remove the site atribute leaving just the innertext attr
why not doing it without clicking the name?
In source/DOM of the page, there will probably be something like this:
<a href="http://www.xxx.com/xxxxxx/your-post-title">your username</a>
Then you just pull the link out of it
eg in the example above, the regexp:
http.*?(?=\"\>your\ username)
will pull out:
Archel I think my query may be in a confused state. but i am not clear with you.
