hello, I have a problem with the path when I save a file.
I had made the "template" for the first time with a different access path and when I made a version "2" I created a new path. The problem is, he refuses to follow the right path.
For example :
New path :
{-Project.Directory -} {- Variable.concession (folder) -} \ Results \ {- Variable.variable_modele_liste -} \ {- Variable.number of the car -} \ options with codes.txt
and it creates:
{-Project.Directory-} Results \ {- Variable.variable_modele_liste -} \ {- Variable.number of the car -} \ options with the codes.txt
however I copy / paste the same path when creating the file and saving the values in the documents.
I think the {-Project.Directory -} is not the same. How can I change it?
thank you for your help
For example :
New path :
and it creates:
