Problem with running code in zennoposter any throttling mechanism
pascoyegbe
Joined
Aug 29, 2011
Messages
Reaction score
Points
Usually in PM you have your project being exeuted from step to step but in CC template everything run through at the same time so much so that that you have less than a second to enter captcha, missed that and your projet will be practically dead, is there a throttling mechanism that make sure each code must be executed in step before going to the next line, (eg WaitDownloading();-) that way when a captcha is summited, the thread should wait for a reply to come back before moving to the next code which is entering th captcha, and should enter the capcher before moving ahead
note that everything work fine, step by step when you deburg in CC but when runing the project in zennoposter the whole thing becomes a big mess, cause code execuction is faster than light
i have tried // pause Thread.Sleep(); to no avail
below is a simple php code with capcher try running this in zenoposter, if you wait for as much as 15 second which is less than the time for your captcha to get recongnise and sent back by any of the captcha recongnition site you project will conclude telling you that it was a sucesful task when actualy it was a wreck
PHP:
<?php
import namespace System;
import namespace Zennolab:::CommandCenter;
class Step1
	public static function Execute($instance)
		// Clearing cookies
		$instance->ClearCookie();
    $tb = $instance->MainTab;
    if (($tb->IsVoid) || ($tb->IsNull)) return -1;
    if ($tb->IsBusy) $tb->WaitDownloading();
    $tb->Navigate("http://lessons.zennolab.com/ru/advanced");
    $he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByAttribute("img", "fulltag", "img", "text", 0);
    $res = ZennoPoster::CaptchaRecognition("MonkeyEnter.dll", $he, "");
    $he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByName("recaptcha_response_field");
    $he->SetValue($res, true);
		// Setting value [jane] to the element with tag [input:text]
		$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByName("fname");
		if ($he->IsVoid) {
			$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildById("fname");
		if ($he->IsVoid) {
			$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByAttribute("input:text", "fulltag", "input:text", "text", 0);
		if ($he->IsVoid) return -1;
		$he->SetValue("jane", true);
		// Setting value [ali] to the element with tag [input:text]
		$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByName("lname");
		if ($he->IsVoid) {
			$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildById("lname");
		if ($he->IsVoid) {
			$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByAttribute("input:text", "fulltag", "input:text", "text", 1);
		$he->SetValue("ali", true);
		// Setting value [pa@yahoo.c...] to the element with tag [input:text]
		$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByName("email");
		if ($he->IsVoid) {
			$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildById("email");
		if ($he->IsVoid) {
			$he = $instance->GetTabByAddress("page")->GetDocumentByAddress("0")->FindElementByTag("form", 0)->FindChildByAttribute("input:text", "fulltag", "input:text", "text", 2);
		$he->SetValue("pa@yahoo.com", true);
		return 0;
Joined
Feb 9, 2011
Messages
1,228
Reaction score
685
Points
instance.RiseMacros("Pause", new[] { "3" });
That is C# but you get the idea.
  • Thank you
Reactions: pascoyegbe
Joined
Jan 12, 2011
Messages
3,441
Reaction score
837
Points
First of all it waits for captcha solving any way and only jump next when it is solved.
In case you need to wait for page loading after synchronous request you should use:
In case it waits for ajax you should use macro pause
$instance->RiseMacros("Pause", array("5")); //5 seconds pause
or
System:::Threading:::Thread::Sleep(5000); //5 seconds pause (in ms)
  • Thank you
